I hope they are sweating buckets and losing money… teach them a lesson.Rip scalpers
i imagine if the drivers were better....Has the 5080 even got out of stock at this point? Each time I look it's happily available - not necessarily a bad thing for availability but really puts to shame the clowns with their FE models on the Bay with an extra 25% cost added.
That offer ended about 10 days after it started so it's long gone.Edit - does it still come with Doom?
Not sure it does anymore, it's not showing that 'special offer' banner anymore.i imagine if the drivers were better....
Missed out on the 5090 FE drop as I know I can't order twice, then got an Aorus Master for less than 5090 FE RRP so a good day for me if it turns up brand new/working.
Nice that was the one I was originally going for with the place that had pre-order queues. In the end, glad I ended up with the Waterforce Xtreme but the Master is also one helluva card, specially with a chunk knocked off!Got it today, and the box "heavily damaged" was some tears on the corners they clear taped and sealed, the rest of the product was brand new and currently using it!
Now I have the GPU I originally wanted at launch and got it cheaper than a brand new FE win/win for me.
I recommend people chancing on damaged boxfrom retailers.
Ah if only....
Still in stockAh if only....![]()
Of course, you still get the same amount of heat from an air cooled card, it's just dissipated from the case in a more diffuse fashion.Watercooled is superior if your room can handle the heat coming off of the radiators, turned my room into an oven with the Astral LC, so happy to just go back to air cooled at a great price and finally call it a day![]()
5090 Founders available if anybody is after one![]()
big thumbs up to notify-fe.plen.io heard the bing bong sounds a few minutes after I closed out of a game on console with my headphones on.5090 Founders available if anybody is after one![]()
The FE is smaller, but all the AIBs will run cooler at similar fan speeds, especiallythe memory. I'd suggest not much in it performance wise vs similar priced cards.With entry level AIBs now similarly priced to FE, which model is better?
Is this the longest so far? It's been just under 45min since the initial alert.oh still up
must resist....
