NVIDIA RTX 50 SERIES - (PRE)ORDER DISCUSSION **NO COMPETITOR HINTING**
Sure, send me the clip.
The test with the Proteus model just finished in 22m 37s.
I'll give the starlight mini model a go with my video as well, although because the original resolution is so low, the max output is 1280x768
On second thoughts, maybe 1280x768 is enough :p
Turns out I was using an old version of Topaz AI. The latest version is much faster, my video is now processing at a whole 1.0fps!
GPU power is now much higher, averaging 450-500W, it was much lower before.
Is that with or without assigning video encoding in the nvidia control panel? I was video converting a premiere pro 20min clip at 4k- default settings it was taking just over an hour. Setup the application settings in nvidia for premier pro and dropped to 8mins. GPU ramps up to max to encode. super impressed.
