- 22 Jun 2018
- Doon the watah ... Scotland
I'd agree with the comments of getting a 9060 XT. Its newer generation features, typically uses less power than older gens for the same output. It also plays nicer with older generations of motherboard slots compared to some of the competition. Your 3600 cpu will be fine for the moment for your uses.
A jump to the 5700X or 5800X would make a difference to an extent, but not as much as the GPU.
You might be able to squeeze some more performance out of your normal system ram. you list it as 2133MHz, which is the default base speed of ddr4. A lot of ram can ( and is designed to ) run at faster speeds such as 3000, 3333, 3666. In your BIOS settings, there may be an option to enable XMP or DOCP for the ram. If you click to enable it, the system might automatically set the faster speed and timings, save those and reboot. Making your ram run faster can yield a bump in performance too for a grand cost of £0.
