So the volume dial on the black is definitely metal and feels nice to turn etc. the unit is smaller than the photos suggest, it's a shade narrower than the PA7 lol. Will get pic up later as am currently out but did manage to have a quick play before leaving.
First impression as a DAC in pre-amp mode feeding the PA7 a balanced signal....
- Yay navigating the full menu with remote! Although the screen is small so everything ok it is small.
- Menu options are plentiful and you can adjust volume straps but only between 0.5 and 1.
- You can hide certain inputs and outputs that you don't use and can assign functions to th A and B buttons on the remote which is cool.
- Gain mode only offers high or low gain.
- Display quality is good, the VU meter looks nice although it's not as fluid as on the X9. I like it to when you play an emulator on PC but the emulator is running at 110% speed instead of the emulated console's 100 that's what the spectrum and VU screens look like to me. It's nice on its own but next to the X9 the 60fps 1080p display wins obviously.
- Adjusting volume with the dial when music is playing you hear the steppings as the volume attenuates, this is weird as none of my previous Toppings had this, almost as if they didn't bother to smooth out volume adjustments so you don't hear the stepping. Can you test this Raymond?
- Need more listening time but the few songs I played it was clear that there is some soundstage difference Vs th X9, DX5 II doesn't present as wide a soundstage although it could also just be the stereo image isn't as precisely placed as the X9 does. This is with the speakers of course so will be able to tell for sure when I test the Arya when back.
- Material fit and finish is excellent in black. Looks and feels premium.
- No noises or hums coming from the internala.
- In typical Topping style the anti slip feet are crap, swapped them for the ones I bought off Amazon and now the unit won't move if I press the volume button in.
Overall for under £300 it seems good. Reserving final verdict until a few days have passed listening to it only with the same music and media I've been playing lately.
It is not a baby X9 though that's for sure (at least as a DAC and pre-amp). It has some unique features of its own though yeah.
To he continued.
To he continued.
