Can't wait for the BoE to announce rates will be held until DJMK's mortgage is up for renewal
I'll admit to saving more and spending less than usual as the rates are high. I'd also like to buy a house one day so a lower mortgage rate would be welcome.
Base rate is there to.balance inflation in the economy. Higher rate = more restriction. Lower rate = looser financial conditions, more money creation and more growth. The mortgage issue is just a side effect of the UK having people on short term fixes, other countries with 25/30 Yr fixed rates don't see this issue.It's all an intrinsically linked balancing act...
High base rate is great for saving but bad for borrowing.
Low interest is is great for borrowing but has for saving.
I don't think there can ever be a perfect balance, but just a fluctuation within sensible parameters.
If you are mortgage free then high interest is great...
If you have a mortgage but also want to save money it's more complicated as then you need do the maths as to whether you should overpay your mortgage where possible instead of saving.
It's why I can see @danlightbulb argument more than djmk. Nobody cares if people get 1% less on their savings.
Getting 3% on savings with inflation at 2% is much better than getting 5% with inflation at 10% like it was recently.. however that point is lost on most people.
What's a decent instant access saver to deposit and keep ~£10k in? I have it in 212 ISA at the moment but a few times the withdrawals haven't been as fast as I'd like. I see Chase have just boosted their saver (again), but curious if there's something better.
I got sent an email today about my trading 212 cash ISA which says it's changing its terms and conditions so that they can change the rate down to 0.15% lower than the current base rate on August 4th. This will make it 4.10% which is what it currently is on anyway.
Have they done this in preparation for an additional base rate change they are predicting to happen on the next BOE meet on 7th August? i.e. 4.25% down to 4.0%, so that they can change it down to 3.85%?
Simply not true. Consumer spending makes up the majority of the GDP of most major modern economies.People spending more isn't going to help a global economy..
You are already in an incredibly privileged position having a mortgage and £40k+ plus in savings. You're obviously not in the position where a percentage swing in mortgage rates is the difference between having a home and not like a lot of people.People spending more isn't going to help a global economy..
Stopping wars will help the global economy. And stop corrupt politicians.
I'm saving because I want to be able to live comfortably and also use the additional interest to add to.help to paying the mortgage back.
Low rates (especially very low rates as seen until a couple of years ago) also means more wealth transfer upwards and higher wealth inequality.Base rate is there to.balance inflation in the economy. Higher rate = more restriction. Lower rate = looser financial conditions, more money creation and more growth.
A lot of people seem to forget/deny just how unusual it was for interest rates to be that low. Without searching for exact data, I seem to recall that when looked at long term the average UK interest rate is over 7%.
Consider also the amount of debt today to buy a house is higher so lower rates feel worse than they appear. Something all those boomers screaming about how they had 15% rates conveniently ignore.
They were pretty much pointless anyway, can do the same thing with a MMF in a s&s isa.Is it pretty much confirmed they are cutting the cash ISA amount making it pretty much pointless?
