Rtx5090 grade b
Couldn't find any post. Are the listed 5090 grade b all missing ROPs?
Probably customer returns for one reason or another, dont have the right PSU/connections, changed their mind, dont like the noise fans etc. Usually nothing wrong with them but if the seal has been broken they cant sell them as new hence b grade. Warranty is down to the manufacturer some dont accept b grades with full warranty some brands do give you the full remaining warranty. B Grade is usually a punt and I've had some tremendous bargains in the past but for that price I wouldnt risk it personally. However nothing to stop you ringing OCUK and offering them price minus £200-£300 they can always say no, or they might accept and you get a nice reduction. End of day you can always return it again if not satisfied. Depends if you have the cash to splash.
You would have to be mental to buy a near 2k b grade GPU IMO?!
depends which one you're after
The Suprim may be worth a punt for someone, especially if you can register the warranty with the serial no provided (and it's not been done already)
Save £500 on new from people who weren't happy with the GPU for most likely coil whine reasons which aren't always due to the GPU itself.
Got my Aorus (which I finally kept) damaged box GPU for 500 cheaper than buying brand new and the GPU was fully sealed with all the plastics and was able to register the warranty.
Do your research and if you can't register the warranty directly return it I guess..
