I always had the same issue in till I removed MSI AB now my settings saveAbout double the perf of the 3060 Ti from what I can see, did another Timespy bench with -80 UV and Memory at 2700 which literally doubles the Ti score
I scored 23 794 in Time Spy
AMD Ryzen 7 7800X3D, AMD Radeon RX 9070 x 1, 32768 MB, 64-bit Windows 11}www.3dmark.com
I only play DayZ but saw the core clock boost to just over 3200MHz a few times playing that game, never thought I'd see that on this card.
I still get some stuttering in DayZ too but Im trying different tweaks to minimise it, was hoping brute force would eliminate DayZ stuttering
And what is with some settings not saving in the driver software, Power slider and Fan controls usually reset after a reboot, gone back to MSI Afterburner for fan control.
Anyone got and gaming temps for Samsung memory on stock fan profile
Not seen mine go over 70c yet in benchmarking or while playing DayZ, this morning I noticed the GPU temp sat around 42c-43c for most of the session and I have a lot of the settings turned up now.. really impressed with this card and cooler, though I forgot to check mem temp so will try and remember next time I play but it wont be anywhere near 70c in DayZ.Anyone got and gaming temps for Samsung memory on stock fan profile
Mine are quite high I've seen 86-88c in stress tests and more demanding games but it is very hot the last few days
It's going to full depend on what other cooling is going on in that case too. Some people might not have any additional cooling at the front of the case etc. Also hard to judge how 'stressed' the cards are if no one is specifying resolution or refresh rate when they check these.So that’s about the same as Hynix ram.
The only thing I can't work out is how to render at a resolution higher than native ? Maybe not possible with AMD but thought it was
I game at 1080p but often on my Nvidia card is redner at 1440p and downsample looked better than applying AA
I've enabled VSR in the AMD settings but it won't let me set either the desktop or any games to above native resolution. Any ideas please ?
Thankyou - I'll try again although I have tried several timesThat's odd. I've just turned it on in the adrenaline software, the screen flickers briefly, now when I go to windows display settings I have new options above my display's native resolution.
I've got mine in the 5000d, so similar to yours.Agreed I think just hot and if wasn't monitored no one would care !
Mine is in a 4000d case so loads of ventilation the GPU itself is quite cool but in certain games/tests the memory is quite toasty
It is running at 2730 fast timings though so that probably has some influence on temps too
I think the hottest I've seen is 90 degs under very heavy load on a hot day.
I've stopped monitoring it as realised it didn't matter.
No, mine is Hynix. It's an OG Nitro+. Hynix has a thermal limit of 108 degrees, so there is 18 degrees headroom on my worst case scenario, hence me not caring at all about VRAM temps. Gaming doesn't even get me close to 90 degs on VRAM.and this is Samsung memory?
