Fitted 3 vertical blinds but broke 4 drill bits , metal mesh on lintel ? Just wondering for future use what I should be looking for in a drill bit ? Type or brand maybe , guessing the generic cheap sets are pants ? Milwaukee drill btw
I think this is true I also wasn't sure on the speed neededSounds like your putting your body weight into the drill. Let the bit do the work not you.
YupBosch professional expert multi construction
No one has mentioned drill but IMO it is as important as drill bits
Anything difficult if you can go wired IMO its a world apart compared to a combi
I've got good battery based and even a cheap wired drill I bought is so much better on demanding tasks
If I break out the wired bosch SDS even in normal drill mode its a beast, using the same drill bits its like 10x easier
I've never had an issue with a fairly cheap battery drill, what are you guys drilling!
I drilled 40x 10mm holes in 8mm thick steel with my brushless Ryobi and didn't have any issues at all.
I let it have a rest half way through as i felt sorry for it at such low RPM there can't have been much cooling but it still did it no worries.
