Had?.... Why did you get rid!I had the K2 HE and can vouch for it! I do want the Q6 Max/HE though as liked the Gateron HE switches so much. Once this Q6 Max is worn out (if....) I will probably upgrade. Unless one is sent for review or something.
Had it for review, non full sized doesn't do it for me but it's Keychron's first proper HE keyboard so I wanted to check it out as it gives good insight into how Keychron has handled HE switches. Better than others as it turns out having also had HE keyboards from other brands inc Wooting.Had?.... Why did you get rid!
Nice one. I opted for the Q6 Max as wanted flexibility of changing the switches.I had a Q1 HE which I ordered from their kickstarter. I didn't like it. Or rather I didn't like form factor, but liked the switches. So I gave it to a mate, and got the Q6 HE recently. It's now my main board.
Yeah, and software and interfaces haven't been standardised yet either.Nice one. I opted for the Q6 Max as wanted flexibility of changing the switches.
HE hasn't been standardised yet as each manufacturer has their own set of HE switches..
My new Eversolo Play arrived today.
Eversolo Play
Hey peeps Anyone else getting one of these? I've traded in my Bluesound POWERNODE with RS. My local store is getting just 4 units in early July. So I've got one with my name on it. :) I'm particularly looking forward to trying it out, especially with the multi-EQ, Smart Bass Management and...forums.overclockers.co.uk
wow that looks mint, built-in room correction as well, do you get a mic with it?, being able to just plop in a CD and it retrieves all the meta data and album art and rips it into WAV/FLAC, this is a very appealing unit.
edit -
It says you can use your smartphone microphone for room correction, interesting.
Luxsin is a sister brand to Eversolo.
I wouldn't be surprised if they copy the Wiim...those can use umik1 with cal file. I have Wiim Ultra.
Do like the bigger screen on the eversolo, but squeezelite for me is a 100% must. I think Eversolo support it, but not sure it's as compatible.
Wow, these things are cheaper than I thought! It even has a built in CD-player?
Damn SwiftiesI am like 10 seconds into Tortured Poets
1 - You said when you plug in the headphones, it does the detect ohm thing on the screen....it doesn't do it for me? which input does it only work with or is it in the settings that i need to turn on?
2 - when I turn the volume, it "clicks" internally as it go up, is that normal?
I can never decline tea from around the world! I have 2 cupboards of teas and tea is my thingp.p.s I own you a pint, or a massive mug of the best tea from China.
