Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Cheers, I am off to Japan in a few months, I'll get you some local teas from there!
By the way, if you ever feel you want to solve the channel balance issue down the line then you could send it in to Mend It Mark who will do a video on it too, only just thought about that, he'd probably love figuring something like that out too. I left the balance adjustment on whatever it was that i found sounded central so you are probably hearing good balance if you're using 4.4mm but if it drifts in future then just re-adjust as needed in the audio settings menu. This only affects headphones, not the rear outputs.
I suspect it might be one of the capacitors, if it is then those are easy to remove and replace, if it's the R2R then if you have the skills to desolder then they too can be replaced, an IC needs finer tools though. Diagnosis on what would need some reverse engineering and additional scopes/tools, that is where Mend It Mark would be perfect.
I used one of those websites to check which value was most central by the way, not music as music isn't controlled enough for setting balance!
Swap the placement with the DX5 *spits*
Definitely to big Raymond, send it off to meIt's too big (That's what she says!) on my desk, it's about half the depth of the desk so will take up like 25% of space.
Besides, it's in good company, the 3 books at the bottom collectively is worth more than the amp.![]()
I will figure out a way to get it onto the desk eventually, I just need to think about how....
Buy a bigger desk. I've got a Ikea galant and it's great fits two big speakers a AVR, and various PC bits
If all else fails, there is ample room on my deskAlright, put it back to 8.5
This is probably the most accesible/convenient place for it that is near my desk at the moment. The 1.5m cable reaches but not much slack, I might get a 2m one later on..
Mine was on 13.0 (13.9 now) when it arrived. I just left it on that until tonight.
I was dragging and dropping the .TOPPING file out the zip file straight into the drive and it didn't like that at all. Didn't pick it up. Had to save the folder to my desktop and then copy and paste it from the folder into the DAC. 30 mins of my life I'll never get back.....
Yeah it's a bit weird it didn't like it directly from the zip file. I thought I was doing something stupid so read the instructions properly and I was following them. Then did exactly the same thing after unzipping the folder to my desktop and it instantly ejected and reconnected with the update screen on the digital display.I did it first attempt on the Mac Mini. I was surprised how easy it was.
