- 13 Mar 2003
- location,location
Does anyone own the Aviator edition? If so how well are the included aircraft working in 2024?
Uninstalled it - total crap. Hopefully they fix the planes and bring them to MSFS2020 eventually.
The rudder twist axis on the T16000 isn't a hall sensor but is instead just a standard pot. It is just the pitch and yaw axis that use hall sensors.Thinking of replacing my Thrust master T16000m - it's throttle doesn't work and the rudder hall movement is going funny. I currently use a TWCS throttle to get around that. I might replace both with a VelocityOne Flight stick? Does anyone have experience with that joystick? Don't really want to pay more than £100.
What do you mean by the throttle doesn't work? Do you mean the throttle slider at the rear of the joyustick base? I don't understand why you would want to use that if you have the TWCS throttle anyway.
If it is just the twist rudder that isn't working then you would be much better buying rudder pedals instead of a new stick. Peddles are much better than twist rudder controls or paddles.
I have 2020, but is 2024 really any better for VR? I find on my Q3 that everything is pretty blurry..
Now go VR!installed opentrack and used my webcam for headtracking today
took about 4 clicks and works perfectly
its awesome, especially in the spitfire
