Don't forget the 3 pin granny charger at around 2.5kwElectric cars have two methods of charging.
AC at 7-11kw with the latter needing 3 phase. This is done via a ‘type 2’ plug (except gen 1 leafs and other first gen cars)
10amps is fine on decent wiring.If you want to melt your wall plug, yes. I knock it down to 8 amps/1.8kw personally…
it's not often I use it (an ipace with 84kwh of usable storage is not really suitable for granny charging) but the half dozen or so times I have needed to do a full 10%-100% charge over a couple of days at my folks house, the plug etc on mine has not gotten above mildly warm. that runs at 2.4kw (10amps) iirc. - I haven't looked into it much but I don't think you can manually change it tho it may auto knock back if it gets too hot)If you want to melt your wall plug, yes. I knock it down to 8 amps/1.8kw personally…
I admit it isn't ideal and if you have any issues with your wiring this will find it out..... but granny charging isn't inherently dangerous imo, you just have to know your house wiring is decent quality
I have a 2021 Nissan Leaf Tekna and love it. It's a deceptively large car really, loads of cabin space. I am 6'2" and with the drivers seat in my usual driving position I can easily sit in the back seat behind with quite a bit of extra legroom and loads of headroom. It's a really comfortable car and generally a nice place to be in. It has a proper dash with no tablet like screen that looks like a afterthought and gadgets galore, mine has the full Pro-Pilot system so it will even park itself if you want (something I haven't used yet), adaptive cruise is brilliant and it's a pleasant car to drive. In the winter when we had snow it was by far the easiest car I have ever driven in snow as it's so smooth annd predictable. It will do 0-60 in 6.9secs if you can get the power down and is brilliant for overtaking. I have a OHME Home Pro charger installed at home as well. I am currently averaging 4.36 miles per kw and as I am on Tomato's EV tariff which gives me 6 hours at 5p a unit the car is costing me 1p per mile, it's hard to argue against that!! The boot is quite large, massive compared to the Ford B-Max I had before it so plenty of room for your dogs. The range won't suit everyone at around 130-140 miles on a full charge in the summer and around 1 mile for every 1% in Winter (very cold up here in Winter). It suits us as most trips are local and around 37 miles round trip with a 125 mile round trip to Inverness/Aberdeen every now and then. I have used public charging twice now and have not had any difficulty in finding a CHADeMO charger which will give just over 50% charge in 27 minutes. My home charger is a type 2 which will charge most EV's and will easily charge the battery overnight in my 6 hour off peak. Mine is my first EV and I have had it almost a year now and don't regret switching to a EV one bit, I certainly won't be going back to a ICE powered car.Nissan leaf, whos got one and whats your thoughts on it??
I thinking between this and a peugot 208 EV next year....
I know they are two quite different cars, but im thinking the bigger leaf might be better with having two dogs to take out and about.
ergh it was in the news that they will make an announcement this week ? ... along with comments about charging station signage,… the government haven’t done anything, way to jump to a conclusion. If you are happy to buy Chinese, we are pretty much at price parity already anyway.
Ironically, the government used to offer money off all new EVs but they took it away because it wasn’t needed anymore.
Glad someone appreciates it. Spent hours doing all that and my girlfriend was singularly unimpressed when I walked her around my efforts.I like that![]()
They trialed ‘something’ in the news but you have absolutely no idea what it is.ergh it was in the news that they will make an announcement this week ? ... along with comments about charging station signage,
Don't you think we should do something to protect uk/eu markket against subsidized chinese one, like the eu have done, though
(but kier wants to announce a trad deal with china so trying not to queer the pitch)
I bought a decent outdoor socket (https://www.masterplug.com/uk/products/ev/charging-socket). Already had a socket directly on the ring just inside the garage door, less than 3 metres away. So I replaced that socket with decent heavy duty FCU (as there was another socket spur coming off it that I wanted to maintain), then wired the new outdoor socket to that with some 2.5mm twin and earth inside a duct.
Just for belt and braces, I also got hold of a cheap thermal camera and checked all the connections after the car had been charging for several hours. The wires and sockets show warm, but not alarmingly so...about 28-30 degrees, almost imperceptible to the touch.
Been like that for a couple of weeks now, charging every night, and had no issues. Nothing has tripped, and from empty it takes about 6.5 hours to fully charge the battery...and our cheap tariff window is 7 hours. So far, we're happy with that setup. May look at a proper wall charger at some point, but the only problem we've had with the 3 pin charger is what I mentioned earlier, that it doesn't have the oomph to keep the battery topped up when you remote start the HVAC. But it's not a deal breaker.
Actually quite proud of this setup as it's quite neat and I didn't electrocute myself so have a picture.
Originally, this FCU was a cheap plastic socket, but it was directly on the ring, which is good. There is another socket at the back of the garage which spurred off it (the wire going up out of frame).
So I replaced the old socket with this heavier duty switched FCU, connected the outdoor socket straight to it. Replaced the indoor socket, again with a heavy duty metal clad one and re-routed the spur for the rear socket to it, so both indoor ones are now a spur from the FCU. Also, the switch on the FCU will isolate both garage sockets and the external one, should we ever need to.
So what used to be:
[Socket on Ring]----[Socket]
...is now:
[FCU on ring]---[ExternalSocket]
[Socket]---[Socket]
ASCII wiring diagrams for the win.
[/S
Hybrid, so battery is only 17.8Kwh.How does it only take 6.5 hours to fully charge the battery on a 3 pin (or do you have a hybrid)?
Probably only about 15kWh usable so your timings sound spot on. Similar story on my one, 12kWh but 10kWh usable.Hybrid, so battery is only 17.8Kwh.
Thinking about it, think the charging time might be 6h50m from empty...either way, it fits nicely into the off peak tariff period.
Love the colour!Got my tesla model Y, £26k with near 40k miles and 23 plate
https://i.~ibb.co~/BVJtFmkn/IMG-20250710-WA0009.jpg
Bought some black wheel covers and a load of cleaning stuff for it too!
