Solar panel production figures
I've got three SSW 525w wall mounted panels, they only do well on sunny days, overcast days they generate very little.
In December they generated 27 kWh, whole system was 193 kWh.
That's disappointing , I was hoping that as the ideal angle in winter is something like 70 degrees, 90 is much closer to 70 than the 30 the roof is on and they would do well
They do appear to be generating a bit better than predicted, but when I look at the figures I do feel a little disappointed, but I need to remember its only a 1575w array.
See this post for a picture of them
I'm about to move into a house with 4kw of panels (no battery) on an older FIT scheme paying 7.4p/kw export rate and 18.95p/kw generation rate.
Does anyone have any advice on if this is good or not? Is there anything I should immediately look to change / move scheme to? I think the current tarrif agreement has another 10 years or so left.
I also don't understand why there is a rate for generation? Is that not just local use?
If its south facing it might generate about 4000kWh per year and you'd get paid 18.95p for these (£758). Say you use about a third of what's generated yourself: you're not buying about 1333kWh at around 25p/kWh (£333) and getting paid 7.4p/kWh for the remaining 2667kWh exported (£197).
So yes its very good.
Thanks, that's super helpful.
When you say used 1333kWh myself, is that usage that will never hit my traditional electric bill? So that's effectively free, or say under a 3000kWh annual household usage, thats 44% never billed to me? Then ontop of that you get the £758+£197?
When the array is generating, any which you use is electricity you would normally have purchased, so you're saving that from your bill. The generation rate is an amount you get paid for what's generated whether you use it or not. The export rate is what you get paid for energy you generate which you don't use, which is sent out to the grid.
Nice thanks, I can see why that means a battery potentially saves you much more.
