SecurityHealthSystray.exe – Bad Image
16 Jul 2004
Home
I have had this error pop up every time the computer boota. I've tried to repair via windows update and have run updates but still this error remains.​
Has anyone else had this? Any suggested fix?​
Might be worth looking in Event Viewer and/or at SMART data in case the disc the OS is installed on is failing, as it is a part of Windows anti-malware it might be worth installing something like Malwarebytes to scan the system just in case.
EDIT: Is this the same as the error you are getting? https://www.winhelponline.com/blog/securityhealthsystray-bad-image-0xc000012f/ if so replacing the corrupt .dll file seems to be the only way to fix it but I'd try and use another method than downloading a random copy of the dll file from online.
That's the one and thats my worry - it's a random file.from the internet!
Crystal disk says drive health is 100%
My laptop had the correct version. I copied it as per instructions and now no popup.. but windows security doesn't run still
