- 18 Sep 2020
Hello,
I'm in the market for a new case as I've recently upgraded to an RTX 5080 FE and fancy a new change for my case. I'll be moving back to university in September so I'm looking at options for something that is easy enough to move around. I've heard good things about moving to an SFF case, but as I've already got an ATX motherboard, I would have to factor in purchasing a new board as well as a case but if it's the right case then I'm not against the idea.
I'm not fussed about RGB in a case, as recently I've started going for a stealth look for my system. What cases would anyone recommend for good airflow as I've currently got a 9800X3D paired with a 360mm CPU cooler/radiator, but I've recently considered moving to an air cooler provided the new case can comfortably fit one.
Any recommendations are welcome. My budget would be up to £150, but I can go slightly higher if the case is right.
