Fixed position wall mount for a 32" monitor?
20 Jun 2025
Here
Can anyone recommend a good VESA 100x100 wall mount (brick wall) for a 32" monitor?
All I can find is these ones that tilt/turn - they always lean and end up tilting down, so I don't want that, nor one that turns, I currently has a VESA stand, and it suffers these issues.
I can't just buy a TV wall mount, as they're too close to the wall and the power/DP cables won't clear even with a right or left angle cable, and the power cable would still foul.
Any ideas?
Depends on the type of wall. If its a brick wall then you can use an arm style wall mount that has a vertical style mount, but I wouldnt use one on a plasterboard wall because they dont spead the load out very well unless you are lucky and there is a wooden stud exactly where you want it. (I used an Invision Ultra Slim TV Wall Mount Bracket)
The TV mounts tend to be better for plastboard walls because they spead the weight well accross the mount. They tend to come with spacers so you can add a bit of clearance behind the screen for connectors too.
I recently used a "VonHaus TV Wall Bracket for 32-70" and had about 25mm clearance using the spacers.
Sorry, yes it's brick :)
Ah I don't want any arms or adjustment etc, I just want a clean and simple 'just clears the cables plugged' type design, like a TV mount but with more clearance for the DP and power cables.
Nice, so by spacers, did you mean one of these:
Or do you mean the black plastic ones that go between the TV and the mount then the screws go through both?
Will go back flat against the wall with 70mm clearance
Shouldn't sag as is double arm
Rather than DIY shop, you can also buy a Spacer and longer screw kit:
You definitely work for VonHaus :P
My issue is, as with the stand I currently have, it's never straight, so I'm always fiddling with it as a placebo, adjusting it slightly left or right a bit :cry:
It becomes very annoying :P
So I was trying to eliminate that adjustment from the equation.
If I could find a small size TV wall mounts, just flat with no adjustment, that would be great!
Do they make one like your link, that only goes up to 32"? I.E. eliminating the bulk/size of that. As that supports big TV's too.
I'd ideally like it as small as possible, being that my monitor only weighs 5.1KG :)
Am thinking of trying one of these height adjustable ones
Sorry can’t say if there any good at all yet as I haven’t bought one yet
Nice, that looks exactly the type I want!
I take it you have no issues with clearance for the cables? Or do you use right or lend handed DisplayPort cables?
Bought this in 2022, it is still holding up my 34 ultrawide monitor with no issues.
Sorry I don't want any adjustment nor an arm. That's what's annoying me with my current stand. It's never straight and then I fiddle with the position and it annoys me :cry:
