Caporegime
- 7 Apr 2008
- Lorville - Hurston
And by many of our seasonal members here.I see the Topping DX5 Mk 2 has been very positively rated by Amir on ASR![]()
What headphones was that with?Honestly thats the exact opposite of my experience of the k11 r2r, the upper end was lacking in detail and its sound stage from the headphone outputs was reduced compared to its line out on the back and other dacs I had for comparison. The lacking treble detail is linked to the r2r dac and the soundstage seems to be its amp implementation. The k13 appears to have fixed these issues so they were clearly aware of them.
Dan Clark AeonsWhat headphones was that with?
My findings were the same with the DAC stage too btw.
6. What's updated
Fixed: The main interface no longer displays "HP DC abnormal" after detecting abnormal headphone amp DC.
Fixed: Audio distortion when switching sampling rates via USB DoP input.
Fixed: Display lag when rapidly adjusting volume in FFT and VU meter interfaces.
Optimized: The 5 system preset PEQs can now be edited (both parameters and names) or deleted directly via the Tune menu.
Optimized: EQ entries in the menu are now displayed as "number + name" instead of just a number.
Added: Option to retain PEQ configurations when performing a factory reset.
Added: In the FFT interface, when adjusting volume, switching inputs, or switching outputs, a large-font overlay appears for 3 seconds before returning to the normal interface.
Fixed: Several other known issues.
Does it have a built in EQ?New firmware for the DX5 II just dropped. v1.49
DX5 II version V1.49 firmware update - TOPPING AUDIO
www.toppingaudio.com
p.s. I can't test the PEQ since the app they released is Windows only. But users on ASR says PEQ seems to be working correctly now but there are still lots of little bugs it seems, it will take a couple of updates yet I think. Saying that, even the X9 for me has/had bugs, like the new VU settings isn't in showing in the phone app, it's still showing 8 when there are now 10.
Same with my fosi k7. I needed a Windows app to tweak eqNot exactly, I think you need the windows app, set some EQ and then upload it inside or something.
No web interface? I hate it when things are needlessly made into applications that will inevitably lose support.
Maybe its more common than i thought then. Pretty sure its not best practice though from a design perspective.That’s the same as the Xduoo, but the XA-02 is £200.
