I’ve just built a new PC that reboots unexpectedly. No BSOD. Nothing useful in event viewer, on boot I see “The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.”
Longest uptime is around 2 days, worst a couple of hours.
I cloned my Windows 10 partitions 0.5TB from SDD to the new NVME and upgrade to W11. 1st time with Gparted in linux (didn’t work). 2nd time with Acronis True Image in win10. I do plan to boot into the old environment as a test.
I’ve caught it twice rebooting. Only had Chrome/FF open, Vmware VM running linux. Outlook was downloading 40k odd emails via IMAP (weird they were not migrated), CPU was around 25%:
Tests done:
No overclocking, voltage at stock.
CPU 2xATX12V 8 PIN connected to PSU. GPU 2x 6+2 PIN connected to PSU.
AMD chipset drivers updated, no unknown devices in device manager. Latest Nvidia GPU drivers.
The mouse/kbd issues remind me of interrupt problems of a distant past. Whist I carry on trying to rule things out I wondered if the enlightened people had any ideas? Any idea to increase logging which might give a clue what the issue is?
- CPU shot up to 90% (was running NZXT cam), mouse pointer was only visible around 2/10th each second as I moved it. 20-30 seconds later system rebooted.
- Desktop was visible, I moved mouse (no pointer that I could see). Bashed caps lock a few times, after several seconds the lights changed on kbd. Then system rebooted.
Tests done:
- Ran “sfc /scannow” & “DISM.exe /Online /Cleanup-image /Restorehealth”, the later fixed somethings.
- Memtest86, single run took around 15 minutes. Passed.
- Prime95, running 70 minutes now, CPU=100% at 57oC. CPU Power started at 60W and has increased to 73W. Writing this text in Outlook, downloading files. Browsing web, everything is very responsive.
- Heaven v4 benchmark. Ran for 15 minutes or so clean, GPU started to get rather warm.
- Crystal Disk Info, just ran all the tests with default settings. Took less then 10 minutes.
