Red flags? Well, let's start purely with the fact that your posts are well written, with correct spelling, grammar, punctuation, and no "txt spk" or other slang. No teenager speaks/types like that unless applying for a job - particularly not a self-proclaimed "charva".
As per the above, you're clearly relatively well educated - which makes it very difficult to believe that you're not familiar with what a "charva" actually is despite apparently being 18, so that indicates again - not who you claim you are. Either that, or a very sheltered & privileged upbringing, which would definitely not enamour you with the local chav infestation - particularly if you speak with them in the same manner in which you type.
Your presumption is that because of my gender, age, and the way I dress I can't be educated or type properly. This is a forum, not Discord. I never said I am a charva/chav myself.
You also have a weird idea of what a charva/chav is, because as a simple search on TikTok and other sites will show, it's a subculture:
