No one talking about the "attack" on the RAF refueling aircraft?
no?
"Terrorism, in its broadest sense, is the use of violence against non-combatants to achieve political or ideological aims"
Classically Terrorism is violence against the civilian population.
yes.
1.1 What is the definition of terrorism?​
Terrorism is defined in legislation under the Terrorism Act 2000. Section 1 of the act states that terrorism means the use or threat of one or more of the following actions:
yes.
you could suggest that the gov would craft legislation to give them the broadest purview for categorizing things they don't want as terrorism?
You could do that with every law possible. I, and the government view it as terriosm. Whether you precieve it as or not, is up to yourself. But legislation says it is.
More money wasted. Why are we so keen on this country to give them everything they want?
Having looked at the law, I can’t see that the PA prescribing falls outside the scope of the law. Whether you agree with it or not is a completely different matter and largely irrelevant at this point.
However, that’s not to say they don’t have the right to appeal.
The judge seems to be allowing it on two grounds: one about process and one about a conflict between the ruling and other laws. There doesn't seem to be any acceptance of a claim that it falls outside the scope of the law itself -- I'm not sure that was even considered though?
Quite, it's right for the courts to consider it if there are good grounds to do so even if they eventually decide that it was legitimately proscribed.
