The Radeon RX9070XT / RX9070 Owners Thread
just as an update - I did a full Safe Mode DDU - reinstalled latest beta drivers
and still no option to select a resolution above Native - don't understand it
VSR selected on and off
GPU scaling tried on and off as well whilst VSR selected
on my Nvidia card I could just enable then select a resolution higher than native ie for the desktop or for games - often I chose 1440p which went then downscaled to 1080p looked great
Not just you I don’t have the option to go higher either only lower.
I am using Adrenalin 25.6.3 and VSR works for me.
Can change res in Windows and games.
I’ll do some research tonight reinstalling monitor drivers I have seen can solve the problem.
I have tried this to no avail :(
I dont' really get how the end monitor could make much of a difference.
Mine comes up as a generic monitor, but identifies it correctly as my Denon AVR - it lists all of the modes correct for my TV so is reading the EDID
really the virtual resolutions should have no bearing on the output - should get scaled to the native resolution
I haven't tried a re-install of Windows 11 as that would be a complete pain but I did run DDU in Safe Mode
Strange. All you should have to do is turn on Virtual Super Resolution (VSR) and I think GPU Scaling and away you go. I have Adaptive Sync, VSR and GPU scaling all enabled. Here is mine in Windows on 25.6.3 (different card I know):
Have you thought about a fresh windows install as there may be corruption in system level files or registry locations?
Are you using multiple monitors? Have you tried with just one primary?
Sorry if you've mentioned all this before.
Just one single monitor - Panasonic Plasma via an AVR
its reading the TV correctly as it correctly identifies the Native resolution and allows me to select any resolution below that
just doesn't' allow for any virtual resolutions > native
I'm running latest beta - 25.6.3
Have you tried directly into the monitor bypassing the Denon AVR?
have to admit I have not - its a bit of a pain to access the back of the AVR
even if it was to work - it wouldn't be a viable workaround
I do have a spare monitor though I could try and plugin directly instead - I'll try that when I get a chance
I would say it would be worth trying, Just to rule out any funky behaviour with the pass through.
I'd bypass the AVR, if it's outside the EDID range it may just throw a wobbly. I've had issues myself. Use displayport only
I use Edge, so can't help unfortunately.
My default browser is firefox and save all tabs, chrome I use the same tabs on startup and I have it run in the background; its usually always in the background.
Think this fixed it. I turned off graphical acceleration. I was trying to reinstall windows (but hit a hitch because I have multiple windows 11 installs as backup, and windows doesn't like that). But as JaysTwoCents says "I digress".
The way I applied my thermal pads was standard, I had some thermal putty pro but bricked it worried about height. So my ram temps could be better. Better than stock.
And as @NutritioN said it is quiet, but can get loud since I have the same radiators as I had before the Mora iv 600.
There was an issue with an older driver (I had this problem) but this was fixed in a later driver. How you fixed it was one of the ways to temporarily get by. Have a search in the AMD driver thread, but if it's happening now maybe it's something else?
Mine is stock. Having freezing issues - I think its only when google chrome is open, anyone else?
Chrome is the issue it doesnt play well with AMD GPU. I get websites where it corrupts the screen when scrolling its a flaming nuisance. Happened ever since I got my 9070 several months go so its been on numerous different drivers. Turning hardware acceleration off fixes it but then some websites are fugly and videos dont play properly sometimes.
Its the only browser that does it so its Chrome not AMD. I`m thinking of changing browsers and I've used Chrome for years. Very annoying.
Edge is very good. Give it a whirl.
