OK this PC has been brilliant but yesterday it started throwing errors, and now is borked. Checked updates, enabled TPM 2.0 and allowed the upgrade to W11. Upgrade completed successfully. shut down after a long evening and picked up today.
I think we have a busted DDR4 stick and the NVMe does not seem to be recognised by the BIOS.
Its been warm and the filter was pretty dusty - so new parts may be required.
Applied a windows update and tired to install League of legends client.
It crashed and then refused to boot - it would post but not get past the BIOS screen.
Pulled the RAM and re-seated - noted its showing only 16Gb RAM in slot B2
Ram is in A2 and B2
So, will POST ok with both sticks but still only shows 16Gb
Dropped the memory voltage to 1.2v and set everything back to auto, from the pre-configured OC as delivered.
No change, boots to BIOS but does not boot the OS.
So I pulled the NVMe drive and re-seated.
Put it all back together and the same result.
Patched the mobo BIOS to latest. (yes I should have done that sooner) No change.
Found the NVME self test - shows the device as a Force 600 but size is 0Gb and selt test generate a result of "not available" or "Error" if you select the detailed version
Do I need new memory and NVME ?
Thinking I will outlay for NVME only 1st and see if it will recognise the drive.
Spec follows:
FS-106-OG OcUK Gaming Scimitar - Ryzen 7 3700X, RTX 3090
CA-24T-CS Corsair RM Series RM850 850W '80 Plus Gold' Modular Power Supply (CP-9020196-UK) 1
CP-3CB-AM AMD Ryzen 7 5800X Eight Core 4.7GHz (Socket AM4) Processor - Retail 1
GX-44X-AS *Build Stock* Asus GeForce RTX 3090 ROG Strix Gaming OC 24GB GDDR6X PCI-Express Gra p1hics Card
HD-069-CS Corsair Force MP600 series 2TB NVMe PCIe Gen4 M.2 Solid State Drive (CSSD-F2000GBMP60 10)
MB-6DU-AS Asus ROG Strix X570-F Gaming (AMD AM4) DDR4 X570 Chipset ATX Motherboard 1
MY-29C-KS Kingston HyperX Fury 32GB (2x16GB) DDR4 PC4-28800C18 3600MHz Dual Channel Kit 1
Ram is in A2 and B2
Spec follows:
