Hello everyone.
Not sure I'm in the right place in terms of forums posts so if someone could direct me where I should be posting that would be apricated, but onto the problem.
I've had the same PC for about 3-4 years now. No issues with anything really. Was a pre built machine so haven't requested anything fancy in terms of audio output, never had speakers, have always used USB headsets, specifically Logitech G35s.
Which I realise are ancient and are no longer supported by Logitech but they have worked for the best part of a decade with no problems.
Except one night a week ago or so now I had a hard crash. PC completely unresponsive. Now usually I would just hold down the power button until it turned off, except this time I used the switch on the back of my case directly on my power supply.
When I turned the PC back on the headset was no longer recognised as 'Logitech G35' on my sound mixer but now listed as 'USB Advanced Audio Device.' I messed around with old drivers software etc and nothing worked, so they have been substituted for a friends USB headset which work fine.
If anyone has a fix for this that would be appreciated as well because everything I've done so far hasn't yielded any positive results.
My main concern now is that I have no output for my Quest 3 headset when linked to my PC, I have reinstalled software, drivers and what have you but nothing seems to work. Looking at the audio channels when there is something playing you can clearly see them moving so I'm pretty sure that sound is being produced but just not to my Quest. These being:
Speakers (Realtek High Definition Audio)
U2579G6 (NVIDIA High Definition Audio)
The Quest channel is specifically labelled has Headphones whether I am linked to the PC by cable or by the Airlink.
This post isn't related to the headset, I realise that it may just be the headset that's at fault and not my PC, but I was just wondering if it was possible that I could have damaged something when I turned my power supply off directly instead of using the power button on top of the case, as I feel like I've done some kind of damage to something hardware related.
According to Windows there is a problem with my drivers but it is unable to solve the issue. As far as I'm aware everything is up to date.
Any other information that could be helpful for you please let me know.
Cheers
Cheers
