ASUS ROG STRIX 1000p Gaming- I need Extra Cables
9 May 2010
Cornwall
I have the ASUS ROG STRIX 1000p Gaming PSU and it ships with 2xSATA power cables giving me 6 power connections in total. I need another one of those cables for my set-up, does anyone know of a cable that will work with this PSU?
I have tried three different cables so far and with any third party cable plugged in my PC just will not boot hence, I must need a specific cable, hope someone can help.
Thanks
K
Got the same psu I added a sata splitter cable, works fine as I just installed a single sata cable from the psu but I ran out.
Do not under any circumstances plug any cable not supplied with the psu or that isn't specifically made for that psu because you will end up frying something. What you need is a splitter cable that plugs into one of your sata plugs or even better your molex connector as they are unused. You should be able to pick them up for less than a fiver each.
Molex to SATA, that is the solution and it is not even complicated.
Thanks
Top bloke!!! Hat's off to you sir, I have downloaded a great many assets from your website. It's a shame we lost UK Trainsim but sites like yours keep the sim alive. Many thanks to you. :)
