the rsults are in, card didn't work at first, so squeaky bum moment from him to start with, he is competent enough to put his own parts in now, then oddly he decided to reset the BIOS then the card worked, phew, let's see how the card fared in some games all @1440p,with dlss on:with a 7800X3D and32GB 3866mhz DDR4 ram running at 4000mhz, the card was overclocked before testing, achieving an extra 1/4 core, andanextra 1/4 on the memory, this proved stable in 3d mark, and for all the game testing, today he will try and push that overclock further to around 50% increase on both core, and mem, I dunno if the ddr7 ram is going to play ball there, but we can hope ,so
WOW CLASSIC MOP ARENA , fps went up to a bonkers 600 fps, this was good to test the temp of the card, and for coil whine, it only hit 55c, which isn't too bad for an overclocked card with only two fans, there is no coil whine let's check those
other games:
OBLIVION REMASTERED medium settings: went up from an almost unplayable 50fps to 100 fps,so he can give that game a proper go now, max settings was not tested
HUNT SHOWDOWN 1896: went from a variable 60 to 120 fps on medium settings to a stable 230 fps on medium setting, and a stable 140 fps on max settings
PUBG: this is where things become interesting, this went from a stable 80 fps on medium/low to a stable 310 fps on ultra, this is quite a big leap going from low/medium to ultra, and getting more fps, we think that PUBG must be well optimised for dDLSS4 here?
MARVEL RIVALS: this is what pushed the need for a new 16GB card because a recent update had stopped the 8GB 4060 from being able to run the game, now it runs with 16GB but son was too tired to fps test the game, after a day at work work, stressing about making the card work, and testing all the other games, today we will fps test marvel rivals, and rust
worth noting that his lag during streaming has totally disappeared now!
So, overall we have had good success here,
again, no trouble from an ocuk B grade item, and the card is definately an upgrade from the 4060, okay, we have not maxed out the 240hz that his monitor is capable of, but a 5070ti upgrade will sort that in november for his birthday
bviously we do not have a 9060 to test side by side, but
this review does ( pay close attention to the gaming benchmarks)
