Seems more like a by-product of adding in different performance profiles (as mentioned likely for the rumoured handheld) - adding the option and allowing devs to patch their games to ensure they can scale down (rather than just scaling up for the Pro), means that there should be a bigger selection of existing titles supported on day 1 for the handheld, rather than Sony having to "force" devs to patch and add Handheld support.Sony is brining a new power saving feature to the PS5. If you enable it, your PS5 will use less power while gaming and no it's not free - your games will have lower performance but at least you're saving the environment I guess lmao greenwashing Sony
The bigger news seems to be that DualSense controllers can now be paired with multiple devices.
New PS5 system update adds DualSense wireless controller pairing across multiple devices
Update rolls out globally starting tomorrow.
