I went back to 10W, 15W got too toasty for my liking and it even eventually fried out the wireless charging on my old Pixel 6 Pro. Definitely slower but the temps are more reasonable.
Varies depending on the phone's idle drain and battery size. Assuming it's the standard S21 I'm going to guess ~2 hours, maybe more.Well a 10W charger is only £14.99 so that's ok. To charge from zero to 100% on my S21 is in the region of an hour and a half or so. Roughly how long would 10W take?
Generally no, a lot of products have their own specific wireless charging setups.are all wireless chargers supposed to be the same? the only one I have is on my Ebike.
I tried my toothbrush on it and my watch but none of them charge, they act like its not enough watts or so.
you can get USB C cables that support 240watts btw for charging laptops etc, most phones probably support like 30-100watts fast charge.
Anker 515 USB C to USB C Cable, USB 4 Cable 3.3 ft, Supports 8K HD Display, 40 Gbps Data Transfer, 240W Charging USB C Charger Cable, for Type-C Laptop, Hub, Docking, and More : Amazon.co.uk: Computers & Accessories
Anker 515 USB C to USB C Cable, USB 4 Cable 3.3 ft, Supports 8K HD Display, 40 Gbps Data Transfer, 240W Charging USB C Charger Cable, for Type-C Laptop, Hub, Docking, and More : Amazon.co.uk: Computers & Accessorieswww.amazon.co.uk
As mentioned Qi is the standard pretty much all phones support. Some watches do support it but not all of them, a family member's Galaxy watch 6 works with it, my older Galaxy watch 3 didn't. Toothbrushes uses their own thing. Earbud cases also usually support Qi.are all wireless chargers supposed to be the same? the only one I have is on my Ebike.
Do the decent chargers still have little fans.
I asked about these chargers a year or 2 ago. People were saying the higher watt chargers had little fans and I couldn't be doing with the noise if it's next to my head in bed
The Samsung Duo charger has a fan & it's genuinely whisper quiet
No good for me if it's at the side of my head. Anything keeps me awake
