That makes this a bargain considering the stream deck is like £100 for a little one. Provided the apps on this covers what you want.
fully customisable
i've got a few links to work spreadsheets for quick access our dispatch software and a few of the usual apps outlook etc.
you can also set your own images or gifs for each one as well
Some more things to stop me dying when I fall off cliffs.
I am broken.
I'm assuming no VAT, tax deductable etc. If you're interested in tech and have a company that will buy you what you want, it's an easy thing to get into. My home stuff gets upgraded ridiculously often. My main laptop is a MBP 16" M4 Max...then bought an M4 Air to use on the couch...missed the 120hz screen, so gave that to my daughter and bought an M4 Pro 14" etc. Repeat, while ignoring the Samsung Galaxy Book 360 5 and the SnapDragon Surface etc.
I'm not proud.
Emergency order to hold me over until the AirPods Pro 3 come out (which I'm hoping is in September).
Are they any good these days?
Beats used to get absolutely hammered for how poor they were. Which has always put me off even looking at them when in the market for a new pair. Currently on the pixel buds pro 2 which are excellent.
They seem pretty good so far but only listened to them for an hour or two so far. They fit in nicely with my other Apple stuff which is why I went with them. I mean I doubt they'd win any major awards but they are perfectly fine.
One thing they are very good at is staying in your ears. Very secure.
Fiddling with my car, snapped my ½" to ⅜" impact adapter so bought a replacement...
And also bought wheel nut sockets in ½" fitting so I don't break another adapter using the long breaker bar :rolleyes:
And bought some odd little trim clip things as I broke about 6 getting my wheel arch liners out.
Next purchase: new car that hasn't got every single screw and clip rusted, missing or snapped please.
