Thanks. That's why I havent done the paste as dont want to mess the warranty up... its currently on its 4th memory test with no errors yet. The temp is 74 degrees but I assume thats to be expected as its under load. How many test cycles do you think would be appropriate before I reset and try again?
I'll have try and find that post. My 1st machine is running the latest bios with no issues and no tweaks by myself running pfsense.
If no errors after multiple tests I'll just have to try it again .. if it dies after that then like you say I'll have to try an rma... thats going to be fun I bet...
Thanks
Thanks
