Looking forward to seeing it finished.Can you guess what it is yet?
It'll be easy enough to put in some slots for cables once the first part of the glue up is done and I've test fit pedals. I'll then round over the edges and will use the remaining tolex on it to make it match the amp. The flat space at the side is big enough for a vox wah pedal, there's space under it for a power supply or two. Total foot print is 23"wide 13" deep, the pedal section is 18" wide 11" deep.
Just ordered this, hopefully the last pedal I will ever buy
Also started work on building a version of a 176 tube compressor 'pedal' ... it's a pedal in the same way a univibe or fender 63 reverb unit is! I've modelled it in LTSpice (circuit simulator) so now time to build it![]()
So this will be entered into a pedal competition that ends in the coming week. Just rehoming it in a larger case with the tubes on the inside. Once this is back together I'll record some sound. I've made a 'footswitch' which just uses a relay to bypass, and this rebuild has a view update following some tuning adjustments.
I've also got a few bits left over, and for the cost of a couple of transistors and jacks, I should have a fuzz face pedal (NPN AC128 like the original fuzz face).
@Raymond Lin how ls the notadumble going?
