Basic Sketchup , D5 Render Workstation
10 Apr 2015
Hungerford, UK, Earth
Hi all, my corporate zbook, has been re-imaged its now so locked down its basically an email machine with AutoCAD... and no hope of installing anything usefull... I have however been given the go ahead to get something to use "off grid".
I know the below is fine, i use a Ryzen 5900 and GTX3060ti at home for the same thing. increasing the GPU doesnt give signicant gains in D5 render for my use case. (mostly internal office scenes)..
Just wondered if you lot have any thoughts, or spot any errors. trying to not to have anything to RGB or bling.. and i will pick a non windowed case if they come back into stock. I did look at the 7900, but the software is GPU bound rather than multicore CPU.
My basket at OcUK:
Total: £952.87 (includes delivery: £0.00)​
Do you really need an all-white build if you're going with a non-windowed case?
Also the E100 is a scam-tier SSD with terrible TBW, would 100% avoid
I'm guessing your total budget is approx £1k?
Are you planning to game at all on this or is it purely work related?
If no gaming is involved I'd seriously consider the 265K instead, it's hard to beat for the price in most work related tasks.
My basket at OcUK:
Total: £1,122.65 (includes delivery: £0.00)​
Better (on average) work related CPU, more RAM although you could save on the build by reducing to 32gb if it's really not necessary, a much better NvME, more powerful ATX 3.X PSU for the same money.
You could probably save on the HSF by going with an air cooler too if you're not going to be hammering the CPU for prolonged periods.
i've just had a quick look
sketchup = single core thread performance matters most
d5 render = ray-tracing capable GPU with +++ VRAM matters most
so basically asking for a £1k gaming rig :cry:
Hah.
Disregard the above then.
Fiddle in a 9600 and a a 16gb 5060ti if that's the case, should be easy enough for a grand.
Would you be better off giving yourself a decent graphics upgrade and just re-using the 3060 Ti for this build?
Could just bill 'em for a 3060 Ti, but fit a 5070 Ti in his system.
if only the company/HMRC take handwritten receipts :cry:
but to be fair, for gaming, the 7600+5060ti combo would be miles ahead of the 5900x+3060ti combo (or 5900x + 5060ti if one were to do a sneaky gpu swap)
so if i were kurgen, i would repurpose the current pc to be the work pc, and use the new pc as the gaming pc :cry:
lmao icant repurpose, i need to buy this for work without any cheating, thanks for all the suggestions will take on board
