I managed to find the sweet spot with those cheap 24.1 CFM silent fans, as they're intended to be run full whack and be nearly inaudible - I did have 2 other fans I could have used, but they're higher CFM and noisier, so by the time I run them at half speed or less, the CFM would have been roughly the same as the 24.1 CFM maxed quieter fans, so I chose them straight away instead.I just ran fans at low rpm so they weren't noisy, but then they didn't move enough air.
As aforementioned, it just stops the ramping up so often, and does seem to keep the GPU in lower temps for longer - we're only talking 4-6C difference, but on the stock fan curve of my GPU, that makes a fair difference to what % it ramps the fans up to
They were £5 each, with free delivery from elsewhere, so it was worth a go, and I could return them if not
