New Gaming PC - Recomemdations £1,500 budget
16 Dec 2017
Hi All,
Could anyone advise on PC build for a budget of £1,500 for Gaming PC I could push up to 2k if needed but I am thinking of getting a new monitor also so if there is some suggestion on a good monitor to compliment it would be great. I have got separate micro server for large files so storage is for gaming and general use.
What resolution do you want to game at ?
Any preference/must haves , RGB , WiFi, etc ?
Thanks for reply, no WiFi needed, not fussed on RGB would rather have the performance if there is any compromise, in terms of resolution 4K, although I read 1440 is sort of the sweet spot. Probably go 4K, games such as COD, DayZ, Battlefield etc my last pc was built in 2017 so this will be a big step up
£500 on monitor ?
Your in the ball park for an oled monitor check out the AOC AGON PRO AG326UD 4K Ultra HD 32" Quantum Dot OLED Gaming Monitor.
You can also get the AOC AGON PRO AG346UCD Wide Quad HD 34" Curved OLED Gaming Monitor, read reviews on both .
