New PC Build
Hi and welcome.
When you say console do you mean that the case needs slim to fit in a cabinet or is there flexibility there ?
£60 Lexar THOR DDR4 RAM 32GB Kit (2x16GB) 3200 MHz,​
Asrock b520 £90 or b550 AC itx £110 motherboard.
1tb m2 for £45 to £50
650 to 750w atx or sfx/l psu now this will depend on which case you get. £80 aprrox
Have you seen any cases you prefer if yes name them.
is there a sfx or sfxl psu you would recommend. I wont be using stock cooler. Does the Asrock b520 have wifi built in
PSU you can get a Corsair SF750 750 Watt Fully Modular Platinium Refurbished SFX Power Supply for £70 I'd be tempted to get that.
