Did you test this with other controllers? I was wondering if this was related to one of your random Chinese brand controllers, that you use, that also require their own app?If the camera panning judder gets fixed whenever then I will explore getting the game again, at a reduced price![]()
I did ask you before, but you didn't answer
Probably too busy poking people in the ears![]()
None of the controllers need their own app to play, only to configure any customisations, they are all 1000Hz polling though, and controller stick motion does not exhibit camera motion juddergenerally, only mouse movement, but in this game both mouse and controllers show the issue. This is also on controllers costing £229 right down to £45.Did you test this with other controllers? I was wondering if this was related to one of your random Chinese brand controllers, that you use, that also require their own app?
Ah my mistake, I skim read a review that you did the other week, and one of the replies to you was someone complaining that if it required 'another app' that they wouldn't bother with said controller. Ring any bells?None of the controllers need their own app, only to configure any customisations, they are all 1000Hz polling though, and controller stick motion does not exhibit camera motion juddergenerally, only mouse movement, but in this game both mouse and controllers show the issue. This is also on controllers costing £229 right down to £45.
Yeah, that's the only reason I mentioned the appI don't recall that comment, though have been occupied with a lot of stuff so probably forgot.
I have a DualSense (Phantom by Hexgaming, it uses DualSense internals with mods on top), yeah the controller doesn't matter, the game camera motion is bugged.
Most people don't notice these things, like with Last of Us, I was one of the first to say it had camera motion judder online, then weeks later the gaming media picked up on it too.
Different PCs will exhibit different variances as well, and not everyone’s eyes pick up on subtle things like that either. It's not noticeably obvious in this game like it was on past games, but it's there still as shown by the RTSS frametime graph activity. regardless of input device used.
Stupid Epic. But yeah, on 60hz screen with 60fps vsynced I have no judder. My panasonic plasma from 2013 prevails yet again!Screen refresh sync isn't the issue, the cam judder is a well documented UE5 and some others issue and is an optimisation thing devs need to do.. Anyway I am on a 240Hz OLED, the higher the refresh rate and framerates you go the more judder can manifest.
Nice, so for £35 elsewhere for a key, it's worth it for what it is? This was my thinking.I actually finished this last night and I actually quite enjoyed it.
It wasn't the best game but it suited the type of game I wanted to play at the time. The story was pretty good and as someone who normally skips cutscenes I didn't skip one on this.
There's a lot of stealth missions but none were difficult and not all required you to be undetected so you could go in guns blazing if you wished.
Did you have any random crashes/bugs?
NiceIt's not going to win any awards, it holds your hand in a lot of places, but I enjoyed the story etc and the old style shooting. When you complete the game it opens up explore mode so you can go revist places.
There was the occasional graphic flixker, but not very often and only on a cutscene if I remember.
So for me it was worth it, I've spend much more and played a lot less on some games.
What difficulty yiu play it on?There's a lot of stealth missions but none were difficult and not all required you to be undetected so you could go in guns blazing if you wished.
I don't see why not. The only negatives are, that you maybe a bit underwhelmed with the ending, there's a fair bit of linear stealth, and that it's short - ala typical Mafia games.Is it worth spending 30 on this or should I wait
