Was just about to come on here and check, said to the missus, if I plug in now, it'll start to charge.I agree, just got back from Wales and plugged the car in, and it gave me a slot 2pm till 5pm. Is that eligible or not, not clear. So i unplugged and I will have to plug in again later.
Yes, it should be.I agree, just got back from Wales and plugged the car in, and it gave me a slot 2pm till 5pm. Is that eligible or not, not clear. So i unplugged and I will have to plug in again later.
66kw into the car here, got a couple of washing loads done as well.I did 26kwh overnight for 3.5p/kwh.
Nice.
It's not abuse when I leave the house at 0415, the percentage setting is irrelevant as I've got the Hypervolt registered with Octopus rather than the cars so they've got no idea what charge the cars are at and they're both limited to 80% in car anyway.I’ve got home batteries so I’m not completely abusing the IO system
Not sure how long the ‘set to to +100% and a 4am ready time’ to get 5pm slots will last.
The question is will it offset not plugging either of the cars in tonight and therefore cooking and showering at normal rate whereas normally we'd be doing that at 7p. Might do the sums later if I get a quiet half an hour.
Yes, its from my bill. It keeps happening in that 23:00 to 23:30 slot.Well that's 53p more than me, I got 10p. I used 1.3 kWh on that occasion, so should be credited 38p
Where are you getting the rate charged for the half hour charging at 23:00? Only reliable place is your actual bill/statement.
It just had to be plugged in. The issue is if you didn't get a slot in that hour, you were charged at peak rate but then only refunded at the cheap rate, so you're down about 20p for every kwh used.But I thought the car didn't need to charge, they updated the terms.
