- 18 May 2010
- London
I've just started Big But Boring 531.
Don't talk yourself out of it! 3 plates is an achievement on Stronglifts not that many people get to, based on colloquial experience, so go in with it being just another day.Did 135kg 5x5 squat on Monday.
And did 137.5kg 5x5 squat today. As well as 142.5kg 1x5 deadlift.
3 plates on Friday. Feel like I’m gonna fail soon though. 137.5 was really tough.
I can add someDisappointed no curls on C, but there we go. Bro gets to 140kg on 5*5 but still won't go full bro.
I am definitely stronger in the lower body always have been. I want to work on my upper now for sure.3 plate squat is great! Good job.
Your numbers though are a bit out of proportion. Your Squat is super strong compared to your bench and even deadlift.
I would probably try to do more upper body focused workouts. Your bench should be almost 100kg. Triceps and shoulders need some work.
I also would try a much heavier deadlift, like 180kg. You can squat your deadlift! I am sure there is more in the tank for deadlift. Unless your squat form is full ROM, then its a different story.
You might laugh at this but when I was doing 5x5 and gradually getting stronger, at one session I accidentally put the wrong weight on (was meant to lift 120kg but instead it was 140kg) for deadlift - it went up! Was not sure about the form, but just then a puregym trainer came up to me and complimented the form with words of encouragement. Thats when I realised I should probably lift more weight for deadlift.I am definitely stronger in the lower body always have been. I want to work on my upper now for sure.
Most I’ve done on bench is 72.5kg 5x5.
And for sure I’ve got plenty in the tank on deadlift.
It's at that point I would start really questioning my form...but just then a puregym trainer came up to me and complimented the form with words of encouragement.
Age just isn’t fun. I miss the 8-9 training days in a row I could do with the aggression I used to have in the gym, including big days like deadlifting followed by another day of big lifts. These days I’m lucky if I can do 1-2 without it impacting subsequent workouts. Can’t deadlift anymore, can’t do standing rows. Numbers still decent for my age on the things I can do, but plateaued on most things. Arms of all things are one of the few muscle groups that keep gaining despite the odds. Shoulders also not too bad!
Going to start throwing in some short jogs on non weight training days I think.
Still holding a reasonable max of 170kg or so on bench and 250kg or so on squats. I always wanted 200 on bench, but it wasn’t meant to be. Happy to have exceeded 200 on squats that I never thought was in reach when I started. A few more years on my side and 300 was nearly in reach.
I still have a weird pain after squats a week or so ago, although it may be unrelated. Hoping it just goes.
How old are you for reference?
I'm turning 44 this Nov.
Ok. This was incredible. Did first workout of the new routine.
This video seems very enlightening and I suspect highlights where I'm going wrong that leads to the arm pain. I suspect the bar is too low, causing it to slip, putting more stress on my arms. I have noticed this because racking the weight after my set is harder than getting it off - presumably because the bar has slipped because I am starting from a too low position. As well my grip is very wide, and my wrists are bent. So will need to work on that, I already don't put my thumb under but I don't have the bar on my palms so will look at that. However I suspect shoulder mobility will be a limiting factor here, I found some good stretches online so will try those.
I think about this too, brother.Weird. I know it was 10 years ago. But this part of the forum was absolutely buzzing when I was at uni (2011-2013), and the gym rats Facebook group was… great fun.
I guess I was young and most of the people here were the age I am now. I expected this part to still be active, powerlifting totals thread seems to be dead now.
