- 29 Aug 2010
- Cornwall
Not sure what cable you're using, but may be worth trying a different DP/HDMI cable?I apologise if this isn’t the right place to ask, but I thought I’d post in this thread rather than start a new one.
I have a PowerColor Red Devil 9070XT that I purchased in March. Initially, I experienced occasional driver timeouts while gaming. They were infrequent, so I didn’t think much of it.
In May, while browsing, the bottom 4/5 of my screen began cycling through colours while the top 1/5 displayed normally. Power cycling the monitor didn’t help, but rebooting the PC did. This concerned me, so I asked on various forums, but I never found a cause.
Over the next few weeks, driver timeouts became more common, specificly when playing PUBG. At first, it was once or twice a week, then a few times in one week, then it eased off again. Recently, however, it has gotten worse. For the past two weeks, I’ve had two or more driver timeouts every time I play PUBG, with no clear pattern. It can happen immediately after starting a game or over an hour in, whether the PC has been freshly booted or running for a while.
Today, when I booted my computer and logged into Windows, the screen stayed black with orangey pink flecks across the screen before the image went back to normal. It didn't last long so I was unable to get a picture. Later, I had two driver timeouts without gaming, once while idle and once while browsing which was not common.
I’ve checked Event Viewer but haven’t found anything, any advice on specific terms to search for would be appreciated.
I did wonder about overheating but I think this all looks within normal.
Temperatures (monitored with HWiNFO64, room at roughly 27 °C):
Gaming (default fan curve): GPU 60 °C, Hotspot 90 °C, Memory 95 °C, 100% usage, TBP 330 W.
Idle: GPU 40 °C, Hotspot 45 °C, Memory 64 °C, 8% usage, TBP 18 W.
Troubleshooting so far:
Tried multiple cables, monitors, and TVs.
Tested several driver versions, including 25.8.1.
Used DDU to uninstall drivers and install fresh.
Reinstalled Windows (twice, on different drives).
Reseated the GPU.
Tried GPU in a different PCIe slot.
Changed desktop resolution (1440p → 1080p).
Lowered in-game resolutions.
Checked power cables.
Applied a custom fan curve to improve cooling.
Underclocked the GPU (per forum suggestion).
At this point, I’m unsure if I’m missing something obvious, if it’s user error, or if the card itself is faulty. The randomness is driving me crazy since I can’t reproduce the issue at will.
System specs:
Windows 11
AMD Ryzen 7 9800X3D
ASRock Nova X870E
Arctic Liquid Freezer II 360
32 GB CL28 6000 MHz Corsair Vengeance
PowerColor Red Devil 7900XT
2 TB Lexar M.2
2 TB Crucial P3 Plus M.2
Corsair RM1000x PSU
Any help, advice or suggestions would be greatly appreciated.
