Buy a 12th gen and leave it out in the rain so it rusts so you don't feel left out and missing what you once had?The question is when the 14700 rusts to death what do you do if CEX have no replacement?
It's great, provided you understand the risks and are comfortable with them. If it's a seller with good feedback and you can return it, why not assuming it's better value.
CEX needs the warranty as most of their hardware is untested beyond a sniff test.
Yep, for storage I certainly basically only purchase new. But CPU/RAM/Motherboard I don't have any concerns buying 2nd hand if the budget requires it.I think depending on the item a lot of people prefer to buy new for the security of warranty etc but I have no issue buying used, a lot of my system now is a mix of new and used.
mb/mouse/kb/ram/ssd and until recently GPU all used parts, yes you run a certain amount of risk so to speak but there can be some deals to be had.
