I've been meaning to do this for some time, but this morning I set my alarm for 5:35am (so, technically before the sun was even up) and got out on my bike by 6am. Now, I often leave for work around 6:20am and I'm always surprised how many other cars are about, but then that's the M25 mainly so I couldn't believe how quiet and peaceful it was this morning.
Glorious! I've a clubmate swears about
being out early for a pre-work ride. Got several
Zwift friends who do it too - either out for the sunrise or there's several
Zwift group training rides at 6am. I've always thought I would when the dog wakes us up early... But that seems to be 3-4am and I go back to sleep & not the 5-5.30am I'd need to get up! Also starting work at 8 (ish - I'm never there there for it) means I'd need to be done by 6:45 - as my work alarm goes off then and barely have any spare time in the mornings...
@SoliD - any CX yet? Just started here, spotted some good pics + vids on
clubmates activity you'll enjoy
new chain... do you remove links before installing ?
how do you check how many you need to remove or is it a specific number..
Think the others pretty much covered this and Andy advised to do what I do... Don't fall down the 'oh I'll just count the links' nonsense as you'll drive yourself mad. Just hook the old over something (usually over something else hanging up in the garage, even a pedal of the bike on the shelf) then put the new one up alongside. Directly measure link to link. You can even lay it on the floor if it's quite clean (chain so you don't end up with oil on the floor, floor so you don't end up with dust/dirt on your new chain).
If you're changing components (chainrings/cassette) then best to use a tool like Steve said to calculate links, but you can also do it by eye. If you do, always go one longer than you think! Much safer to need to remove 1 more, than ending up with 2 joins on your chain like Andy did... Not that it really should cause much issue - just have to be aware of them as it gets older, QL/ML are not as strong as real chain links, especially if reusing them...
Before. I compare old chain to new chain... although I then cut at the wrong point and have two sets of quick links holding my chain together now.
Been there done that. Also twisted a chain and had to take a link out, replaced it with a QL - although did find that chain quite rough afterwards, probably other bits twisted too and should have removed a section of chain rather than just 1 link.
Anyone else have random 3-4 links of chain and just throw them into a pot? Always trimming a 118L chain down the same length. I probably have enough bits for several complete chains! Pointless keeping more than 1-2 of them really - for the scenario above. Having lots of QL's is more valuable - tend to reuse mine 2-3 times so have a nice pile of those too!
n+1 you know the rules
Plenty on there you can upgrade too! Not to mention all the bits you could 3d print... Can you print carbon?!
