I doubt it will be much faster or even worth the upgrade for normal 9950x3d, let's se what happens. 5-7% faster at best.Dual X3D CCD cache 16 core CPU incoming?!!!
AMD Ryzen 9000 CPU with 16 Zen5 cores, 192MB of L3 cache and 200W TDP reportedly on the way - VideoCardz.com
AMD reportedly finally launching dual-X3D CPU Leaker says there’s a 192MB L3 cache SKU planned. Hardware leaker chi11eddog, known for ties to board manufacturers, claims that AMD is preparing to launch a Ryzen CPU based on the Zen 5 architecture with a higher TDP than current models and...videocardz.com
Amazing if true! no more silly thread scheduler bugs.
200W TDP suggests a frequency bump also!
I dont think there will be any notable architecture change that will resolve cross CCD latency issues.Dual X3D CCD cache 16 core CPU incoming?!!!
I anticipate single CCD models will still be better for gaming, irrespective of the new model having 3D cache availabke on both CCDs.
hello, i wanted to ask a question, my 9950x3d shows in ryzen master the ccd1 stopped when i play, but if i use hwinfo i can see all the cores working, ccd0 and ccd1, which of the programs should i believe? i have a set up with asrock x870e wifi, with pbo activated, with ccd0 -35 and ccd1 -30, 1.25v scalar auto, plus 50mhz, it works like a charm, in cinebench i get 46800 points with artic freezer lii 360 pro, my equipment is running excellent, it may or may not burn with the asrock motherboard, that is not important to me since I have a warranty in case you wonder. thanks
Yes, I tested both together. rm shows ccd1 asleep and hwinfo shows the cores are running at 5700MHz. I updated rm to the latest version and reinstalled it, but they're still the same. Performance is still excellent, but I wanted to know if this was normal behavior. Thank you very much for your response.Nice overclock and cinebench score!
try a reinstall of RM and reboot, it can be temperamental. Have you tried running both at the same time to verify the cores? On rare occasions the core parking will relax (i.e. lean on the non-gaming CCD) if there is a CPU-intensive game.
This is what people have been asking for.Dual X3D CCD cache 16 core CPU incoming?!!!
count yourself lucky.. 14900k is running close to 200 watts!BF6 beta is pushing my temps to a whopping 70 degrees. It’s as high as it’s ever been.
The police could mistake these 14900k users as cannabis farmscount yourself lucky.. 14900k is running close to 200 watts!
I'm sooo glad I switched to 9950x3d, it's been absolutley solid.The police could mistake these 14900k users as cannabis farms![]()
Yeah mines been the same. Can’t recommend them enough!I'm sooo glad I switched to 9950x3d, it's been absolutley solid.
You reminded me of this old classic.The police could mistake these 14900k users as cannabis farms![]()
