Quick budget 43” TV options?
20 Oct 2002
London
Mother’s old TV has a white spot on it so from what I can tell it’s broken.
She’s looking around the £300 mark. I’ve never owned an LCD TV in my life (only plasma and then OLED, both Panasonic) so I’m fairly out of the loop. Getting a Panasonic might be helpful as I’m guessing the options/menu may be similar for those all important remote IT support calls :o Was thinking that or Samsung to support all the HDR types.
So either;
Panasonic TB-43W61AEY​
Or
Samsung UE43U8000F​
At a first glance? She’s not sure the legs for the Samsung will fit on her stand - so that’s another point to the Panasonic. Anything else out there we should be considering? It’ll be used with Virgin TV (probably not even a UHD sub but whatever :o )
TIA
I'm not sure how similar Panasonic TVs are but Samsung were fairly consistent and it made a transition easy when helping older relatives upgrade. Any HDR or fancy 4K features were of course lost on them and they were just happy to have a decent working TV again.
Something like a HiSense or LG, from Richer Sounds with a bonus 6 year warranty fail safe? Most on there are 1 year but RS give you an extra 5 years.
Or failing that John Lewis do something similar, but with 5 years warranty.
Yeah when you don't care about the quality of the set I guess it's best to include a guarantee. Definitely buying from JL or RS.
I noticed just now that the Panasonic sets (W61, and W80) don't actually have 4k upscaling. Is that gonna mean content on her HD Virgin sub is gonna look fairly terrible?
