Could you explain this a bit more? If i use e.g. 60kW in a day, if I've got that much stored in my batteries from overnight it'll all be at the cheap rate so a huge saving no? And as you say I'd probably need to get three phase as well to be able to charge that much overnight.
With 3xfridges and 3xfreezers, that prob going to be 10+kWh straight away just on normal settings/temps. What's your heating source/setup in the whole house? Definitely no immersion heaters on for any water tanks, as they guzzle electricity. Time to get a few Tapo P110 or alternative elec...
forums.overclockers.co.uk
Heating system is gas boiler, with a bunch of pumps and storage tanks and things. Swimming pool is also heated via gas boiler as the ASHP has a fault that I don't want to spend £1000 to fix. Sauna doesn't get used much. The pump/plant room for the house's heating and hot water uses about 0.6kWh 24/7.
Ah yes, I remember now, just lots of stuff.
As for not needing 60 kWh of batteries, you need to factor in that a chunk of your consumption will be in the off peak period so you don’t need any battery storage to cover that consumption.
Then also consider any other loads that you can confine to the off peak period like hot water, dishwashers, washing machines, dryers etc.
Then you can factor in you having a large roof, you’ll be generating a material amount of electricity for 9 months of the year and a non-zero amount over winter.
In summer your batteries are only covering a few hour gap when the solar isn’t generating and the off peak period. The benefit they are adding is negligible.
The goal isn’t zero peak take electricity, it’s lowest cost. You need to factor in the cost of the batteries and the benefit they’ll bring.
As mentioned above, you can only buy them in chunks. Say you needed 42kwh of batteries to cover your day time use but you can only buy them in 10kwh chunks for that system. Spending £3k on a 10kwh battery to cover 2kwh of usage will cost you more money than it saves over its expected useful life (say 15 years). You’d be better off just drawing from the grid.
TLDR, the more solar panels you have, the less batteries you need. Savings from the panels scale linearly with size, the opposite is the case with batteries, the benefits go down the bigger you go.
That seems dirt cheap for the amount of battery! I've heard it's difficult to find an installer for these Fogstar batteries though?
installers won’t touch fogstar, the best you’ll get is the they’ll install a hybrid inverter with no batteries but they’ll wash their hands of it if you want to DIY the batteries so you’ll probably get no support and zero warranty because you’ve materially altered the system.
Installers have generally have enough work that they don’t need to engage with semi-DIYers and they’d prefer to supply the whole system because they can apply their mark up on the parts and make more profit.
