Hi chaps - long time no post from me (in here anyway) *waves*
Well, I have solved my 5090 coil whine problem at last
After returning a Suprim, an Astral, an Aorus Master and a Palit Mirror Infinity, I finally settled on a MSI Gaming Trio. Still a bit noisy with the fans, so I water blocked it… this is the way for temps.
I still wasn’t satisfied with the overall noise though and, lo and behold the solution is… a pair of Apple AirPod Max. These are aggressively expensive and due a product refresh but the noise cancelling is the absolute ****. It’s like god himself installed himself into the AirPods and said “all noise, be gone!!!” - far superior to my Momentum 4 headphones.
It’s almost supernatural - I can sit next to my machine with it blaring whine and fans over 1000 rpm and I can’t even hear it.
I can actually sit there and enjoy a game. It know it sounds a bit sad, but I almost cried when I realised the struggle was over.
So for anyone else distraught - this is a real solution to the problem.
Currently running the card overclocked with a 350hz boost, nicely hitting 3100-3200. Temps at low 50s degrees, can’t hear it. Winning
