less than 400? I can't find one on there for that, that's a good price. Closest I can find is 612 euros which is 530 ish pounds. If this is a UK special deal, then I'm extremely jealous! Not that I want to replace my X9, but something cheaper as a headphone amp for the bedside table, that could be streamed to, would be my next purchase. Going to try the poly unit for my Mojo 2 though, as that can be moved about.If anyone is interested there is currently a sale on on AliExpress and the Fiio K15 can be had delivered inc VAT for <£400.
My only slight gripe is that when im using it with 3.5mm AUX cable, the audio is a lot quieter than whilst using bluetooth. Not sure if its a bug but yeah find it a bit weird
Yeah, the impedance value going from 48 (unit on) to 16 (unit off), Sensitivity 103 (unit on) to 102 (unit off) on the cable, doesn't seem like a lot, but it must be enough to stretch whatever the 3.5 socket he's plugged into. I do wonder if turning it on would help though. He might just be using a particularly low powered motherboard headphone output, and it will be the same in both modes?According to the specs the impedance and sensitivity vary depending on whether the unit is turned on or off.
That's a pleasant surprise which makes the DX5 II @ £282 an even sweeter deal.No, customs have not asked for anything on an aliexpress order the last few times
I ordered my Edition XS from there and it was no Customs.....but now that you mentioned it, my Xduoo amp had VAT to pay. That was £150 (RRP £200 in the UK). So I still came away better off.
I also ordered something computer related so can't mention for £220 which didn't get caught, which was heavier and bigger than the Xduoo XA-02.
