According to the specs the impedance and sensitivity vary depending on whether the unit is turned on or off.
I am interested to find out what that results in. With the increased impedance and decreased sensitivity from having it turned off, it is going to need more voltage to drive to the same volume. I presume it's got a separate analogue in curcuit, which outputs to the other one, which can be powered or not from the in headphone battery. Perhaps having it on could apply some more gain from the headphone side. If not, then the gain needs to be applied from the other (pc or in between) side.well my use case is that I would use wired when my battery is dead so its considered off. Does that really make that big a difference?
To get maximum quality I would need to have the headphones turned on and be wired?
You can buy mrk's for cheap in 2 weeks when he's done with itI think I need to let the dust settle on the K15 and K13 R2R and see if I'm interested in either. I tried watching the above review although it's hard going with the AI translation. I'm not sure I want, or like any of the media/screen/app stuff. I suspect the K13 is probably 'enough' for me. Although I've noticed I tend to use the current Fiio K7 more as a interface and pre-out for speakers. I don't really use the headphone out that much as I prefer my iFi and Gremlin for headphone music listening.
You can buy mrk's for cheap in 2 weeks when he's done with it![]()
How many headphones do you have? An amp per headphone seems perfectly reasonable. This is what they mean by balanced, right?A full R2R Dac amp is tempting but I do not need a 5th headphone amp lol I am not even counting all the dongle DAC amps that i have.
12 headphones and 11 DAC Amps
Nearly there, space for one more DAC
I didn't realise you had a HD 580 alongside the 600. Seen a few of those pop up on eBay in various states. Again been tempted to pick one up to refurb, but then common sense kicks in.
Re: the K13 R2R I can see why it might not makes sense necessarily if you have highend gear already. One nice thing is the K13 & 15 both have balanced out for my Gremlin. However the K15 goes a step further and includes RCA inputs the K7 has along with RCA outputs. That would truly make it a control centre for me.
That does seem to be a thing with more expensive DAC/AMPs you get more I/O options.
Yeah, I paid like £65 for it, about 3 months before I got the HD600 all those years ago. It has been my daily for yearssss, which is why the HD600 stayed in the box. The plastic they use on this makes it very durable.
580 Precision, or the special edition 580 Jubilee?
I've read some even prefer it to the 600 although again it's going to be subtleties I imagine.
It’s the one came out like in the 90’s.
I’ll get a picture for you later.
