3D printing services and cost?
it's about £10 of filament. your real issue is that it's bigger than a standard print bed.
expect to pay about £50 from somewhere like pcbway depending on filament.
if anyone here has a 25+cm bed then they may be able to do it really cheap + postage
Thanks Vent. I didn’t even think of that as a possibility, if anyone does have the ability to then of course paying materials, time and p&p would be the least I could do!
I can probably print it for you, depends how quick you need it and if my printer behaves itself lol :)
That’s incredibly generous @Dano if you are able to. No pressure.
Let me know the cost etc and I’ll sort you out :cool:
Re: how quick, not at all, whenever you have a chance. No need to prioritise.
@Kol Just checked and just about fits on my print bed with no issues, I only have gloss black PEtG in stock at the moment but costs a little more than PLA but is stronger and less susceptible to warping if in direct sunlight or heat, depending if it could be packaged safely to fit RM large letter £20 posted should cover it.
Okay, my printer is definitely giving me grief so if JRJ can sort it that might be best :)
Don't want to tread on your feet, What issues you having?
Just been trouble shooting mine whereby it started dragging across infills completely out of nowhere, scratching my head all morning, messed with settings and calibrations.....blah....blah turns out it was a checked box post firmware :mad::cry:
Hi chaps ! Ha. Well whoever can I will so if Dano it’s a chore let me know. No harm in getting two if you already sorted it, don’t want you out of pocket so ping me a PM.
@JRJ that’s great. Pm me and I’ll sort some cash.
No worries @Kol let's see what @Dano says, if he's struggling I'll sort this tomorrow.
Thanks chaps. JRJ, happy with the cost etc. so if @Dano has no luck let’s go for it!
@Chaos666 appreciate the offer too, if I need a second (possibly) then I’d be right up for that.
Sorry, been busy with family stuff for the last several days, hopefully somebody has this sorted for you now?
