I’ve got one of the ugreen enclosures with a WD Black 1TB drive and it works ok most of the time but then sometimes doesn’t. With that and the two Samsung usb 3 drives anything else refuses to work or they just don’t get detected.I’ve got the UGREEN 40Gbps M.2 TB4 NVMe Enclosure and a 1.92TB Corsair Force MP510 NVMe drive in it. Works perfectly as the boot drive with MacOS installed on it and no compatibility or heat issues.
I’ve had my UGREEN CM642 40Gbps M.2 TB4 NVMe Enclosure with the 1.92TB Corsair MP510 drive in it since mid March 2025 used everyday as the boot drive for my Mac mini M4.I’ve got one of the ugreen enclosures with a WD Black 1TB drive and it works ok most of the time but then sometimes doesn’t. With that and the two Samsung usb 3 drives anything else refuses to work or they just don’t get detected.
My bank manager hates you.That is the one regret I have with my M1 Max Mac Studio. I only got 512GB of storage.
Under the desk.Might have to rethink where I put it, much bigger than I expected.
Yeah, have been considering that. I've seen various mounts for sale. Did you print yours yourself?Under the desk.
How do you get the old about this Mac view? Edit - https://github.com/2009-Nissan-Cube/About-This-Hack?tab=readme-ov-fileIn over three years, I've still never heard the fan on mine ramp up.
Remember the Studio was brand new when I got mine, nobody had brackets, there were no designs.I've seen various mounts for sale. Did you print yours yourself?
I’ve been using an EX400U on my M4 MBA no problems for a while, it’s my my video editing drive so gets a good thrashing.Sent the Ex400u back, the M4 wouldn't even boot with it attached to the TB5 ports, worked ok on the front USB-C but was very slow. Tried different cables including the UGreen one that is running my NVME enclosure with the WD Black drive in.
Need to decided what I want to do with storage and whether I bite the bullet and buy a NAS and drop the locally attached drives.
Need to decide what I want to do with storage and whether I bite the bullet and buy a NAS and drop the locally attached drives.
You do t know the half of it I tried three or four enclosures before I stuck with the Ugreen. I want to consolidate down from the drives I have, the WD is quick and I want something like that for the VMs and then just something bigger for general storage and a Time Machine.You’re not having much luck with external drives. Even if you use a 10 Gbps NAS it will only be as fast as front USB-C ports on a mini.
Here's mine in system report...I bought the UGREEN TB4 enclosure, arrived today and working well. Just wish they used a tool less design.
Tempted to do the same to be honest before I blow £1k on an iPhone which honestly I don't need as I rarely use it.Think I’ll return the studio and order one with the bumped up M4 Max, more RAM, and 2TB SSD. Probably completely unnecessary but I intend to keep it for a good 10 years.
Good choice.and 2TB SSD
Question is, do I add the £199 Pro Apps Bundle for Education, or leave that and opt for Davinici instead. Will be editing drone footage mainly.Good choice.
I know it adds more to the cost, but there's a lot to be said for having the right amount of internal storage and not having to faff about.
