Can anyone throw an eye over my new gaming PC build list please?
17 Feb 2011
There's room for saving/improving some things.
My basket at OcUK:
Total: £1,413.83 (includes delivery: £11.98)​
- Better gaming CPU with the X3D.
- Cheaper RAM that'll be just fine as X3D chips aren't fussed about latency etc.
- The AiO you chose is spot on but frankly overkill, the HSF I've linked is more than ample.
- You could go either way with the PSU, although the Lian Li might be better if you opt for the case I've linked.
- Cheaper but on par NvME.
M-ATX build but you could easily shift things into a midi tower for the same money.
That also leaves around £100 in your budget, you could switch the 9070XT to a 5070ti for better upscaling support (DLSS v FSR) and RT, but it depends on the games you play.
Edit: WTF happened to the 5070ti on here? :cry: I'm going to assume the upcoming Super refresh isn't too far off if they're no longer getting stock.
9600X3D is expected to release this year - may be worth waiting if you're not desparate to get it built, and you have room in the budget. I'd expect it'll be somewhere in the low £300's.
My basket at OcUK:
You advise on spending the little extra on 7600X3D? The budget can increase if it makes sense. 9600x seemed to be holding its own in the reviews I saw.
That case is beautiful but I'm a complete noob, I feel I need more space to build into:P
I'd say so, especially if you reduce costs elsewhere, you'd not be spending any more money after all with some shuffling.
I've built many rigs over the years, an M-ATX case like that isn't any more difficult to build into than a larger one to be honest. The only thing that makes things a bit more difficult would be if you've a non-modular PSU, or a PSU with exceedingly long cables. The Lian LI PSU you selected is actually designed for use in the sort of case I linked, that's why it has the funny looking shelf type thing for the connectors.
If you'd prefer a larger case and like the look, there are some well priced ones out there with similar aesthetics.
Revised build with a larger case:
My basket at OcUK:
Total: £1,434.86 (includes delivery: £11.98)​
Still cheaper than your initial post and includes the X3D.
My basket at OcUK:
With this build would I need to buy another two exhaust fans?
@Gray2233 sums it up well - and you will probably appreciate the smaller size footprint of the case.
Everything is just scaled down from ATX - so the space constraints are typically the same (other than PSU cable length - but modular cases reduce this PITA considerably, plus @Gray2233 explained the pitfalls already).
Nope, it comes with four fans pre-installed, you could add more if you wanted but there's no need.
Agreed, potentially just more noise.
I'm a die-hard M-ATX fan now, outside of NvME slots I really don't see any point in midi towers anymore, they're largely a bygone necessity for people needing 3.5" drive bays for optical drives and HDD's without wanting a ridiculously huge full tower.
You don't even need extra PCI-E slots anymore for the most part, granted some do for X or Y but for a gaming setup it was generally just a soundcard or something being slapped in. There's better external solutions for audio now, and that aside GPU's are so ridiculously huge they obscure most of your PCI slots anyway, and I don't know many gamers going for two-fan/slot design GPU's in a midi-tower.
Honestly, I'd shift to ITX if not for the utter faff and cost.
Careful, @tamzzy will appear waxing lyrical about ITX and indoctrinate the whole thread.
I agree, in theoretical principal, especially the M-ATX - easy to work on and cooling isn't an issue.
ITX however has always found a way to **** me off. Cable management, being the biggest PITA. Plus, i have big hands - and this combo doesn't mix well. I'm sure i leave as much of my DNA in an ITX build as silicon by the time I've finished.
I still advocate them - they're superb - if built correctly - but I try and hide my disdain if a family member/friend chooses this option.
Lian Li A3 middle ground incoming! :p
Frankly, the A3 is a grand little case and does support M-ATX at an extremely reasonable price. If I was building a new rig for myself it would be a contender, lots of nice style options for them too.
My basket at OcUK:
Total: £289.79 (includes delivery: £19.99)​
+ A bunch more, the non-window options are about a tenner cheaper too.
Quite keen on the dark wood window version.
Not recommending this to the OP BTW, if you're a little unsure about building it's one of those cases that might be a ball ache.
I feel you know my leanings towards little black, dampened boxes.
It is a beautiful case.
I recently built my daughter a 7800X3d build in Fractal North case - similar style - and I was really pleasantly surprised. So much so, I researched and came across the Lian Li's and became confused as to why Fractal hadn't made a M-ATX version themselves. They look great,
Although, I'm very taken with the Fractal Design Terra Mini ITX - but the blood content in my body disagrees.
