Ideal for doing up sump plugs!I’m going for a Milwaukee M18 Fuel M18FHIW2F12-0 for £249 plus battery cost. Real nut busting torque!!
Cheap ish lolLooking for a powerful but cheapish battery version for occasional DIY use. Recommendations?
I thought the DCF900 had that beat?Milwaukee and DeWalt will take a fair amount of drops, the Milwaukee has the real world grunt over the DeWalt though, I love Makita, but their impacts aren't even close to Milwaukee/DeWalt.
I'd go for the Milwaukee personally, as they do some beast spec stuff, such as this 1000FT/LBS monster - which is currently on offer, and even cheaper than last year when I looked.
But if you're a DeWalt guy, just stick with that, and then you can reuse your batteries with other things that you already own![]()
Nice!!! I hadn't seen that model the last time I looked into the two - around 2-3 years ago IIRCI thought the DCF900 had that beat?
thanks for that, now look what you've done
Apparently they're working on something much bigger as well. I wonder if they are going to use 54V.Nice!!! I hadn't seen that model the last time I looked into the two - around 2-3 years ago IIRC
As I say you cannot go wrong with either, but mechanics do favour Milwaukee and Snap-On, there's definitely a reason for that, along with MAC Tools.
I do really like DeWalt, so that is a tempting future upgradethanks for that, now look what you've done
You'll love it. I got the 892 version as I don't like hog rings.Been bought a DeWalt DCF891 by my kids. Seems great.
I've had the 923 for a few years now and it's been great for everything I've thrown at it. Compact enough to get into small spaces, but powerful enough to shift things. It doesn't get much use, basic mechanical work, brakes etc, but when I have needed it, it's been a godsend.Been watching too many vids on impact drivers following this thread. I like the look of the 923 as an addition to the tool pool. More compact than the 899
899 makes you feel like the hulk mind you
I have a Milwaukee 1/4" extended reach ratchet and love it a lot but I have snapped a couple of wee bolts when tightening them up so I've learned not to just tighten everything up full whack with it.When it comes to smaller nuts and bolts, I bought a Sealey 12V electric ratchet (rebranded and cheaper Milwuakee) I don't know how many years ago (probably 10) and it is quite possibly the best tool I've ever bought in terms of cost/convenience. It whizzes off undertrays, etc. in no time when an impact would simply be overkill. It cost about £60 with two batteries, and I couldn't begin to calculate the time it has saved. I do have DeWalt electric ratchets but always find myself using the Sealey due to its lightweight and very hand tight comparable torque.
That's where the Sealey shines. You can tighten something at full juice and you can still undo it by hand. It's completely immune to overtightening unless you manually turn it by hand yourself and then snap it, of course!I have a Milwaukee 1/4" extended reach ratchet and love it a lot but I have snapped a couple of wee bolts when tightening them up so I've learned not to just tighten everything up full whack with it.
